Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Multiphase MRF Simulation for Achimedes Screw Pump › Reply To: Multiphase MRF Simulation for Achimedes Screw Pump
I don't know what's causing the poor mesh to comment - pictures will help!  With VOF I'd avoid inflation as you need to ensure the aspect ratio is low (ie as near one as possible) for the free surface. Inflation is very good to improve the near wall resolution, but often the efficiency is to the detriment of the streamwise (along the wall) resolution.
