Ansys Learning Forum Forums Discuss Simulation General Mechanical ERROR: A general failure occurred during the solution process. Reply To: ERROR: A general failure occurred during the solution process.
Sampat Kumar
Hi
This appears to be a meshing issue. Do you encounter the failure immediately upon clicking the solve button?
Here are a couple of things to check:
  1. Geometry Errors: Please verify that there are no errors present in your geometry.
  2. Mesh Generation Settings: Try generating the mesh without using the patch-independent and virtual topology options. Use the global settings instead and see if the issue persists.
Best Regards,
Sampat
