Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Artifically High Stress Due to Thermo-structural Analysis › Reply To: Artifically High Stress Due to Thermo-structural Analysis
Thanks for your answer,
Can you explain why the cylindirical support doesn't work in my case? As i mentioned I tried all the combinations for cylindirical support options (tangential-radial-axial free/fixed).
I did try your suggestons but dummy component (adding/drawing another flange) is not allowed, also can you explain remote displacement part a bit more in detail. Because i did try remote displacemenet as: 1)Select 4 boltholes inner surfaces(as it's shown in my figure above), 2)insert remote displacement, 3)behavior = deformable and 4)set the all six DOF to 0.
But the point is once i tried with only one bolthole instead 4 boltholes results were same but constraint was changed. So it's impossible.
Second thing is, do you suggest that path: 1) Select 4 boltholes inner surfaces, insert remote displacement (this time placing remote displacement x-y-z coordinates due to dummy flange component back side(opposite side due to contact surface).(dummy flange which is not necessarily dwarn in this case) )
