Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Why is deflection for fatigue life not at point of loading? › Reply To: Why is deflection for fatigue life not at point of loading?
May 20, 2024 at 4:49 am
Sneha E S
When i apply cyclic loading, ie displacment with a tabular data which has time and displacement in mm, the model shows zero deflection. When i apply force alone it shows defelection, but when displacement for cyclicÂ
loading is also applied it shows zero deflection.Here i have applied both force and displacement on the two rectangular sections, butat the same time when load is applied all over the face and displacement just over the small section it is the only case when deflection is shown.
