Ansys Learning Forum Forums Discuss Simulation Fluids The flow from the inlet did not pass through the golf ball in the rotating domai Reply To: The flow from the inlet did not pass through the golf ball in the rotating domai
Jim Beet
Hi rob manage to do the path line. Im still figuring out how to check the mass flux. From the pathlines, it seems that the flow from the inlet went around the rotating flow instead of merging
