Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Fluent 20.1 – bug in writing a pathlines file by GUI › Reply To: Fluent 20.1 – bug in writing a pathlines file by GUI
May 18, 2024 at 3:48 am
Thank you for your reply.
The TUI commands "/display/objects/create" and "/display/objects/display" could create and display pathlines as IÂ tested in Fluent 22.1. And the TUI command "/display/path-lines/write-to-files" have been removed in Fluent 22.1.
However, the final goal is to write a pathlines file. No matter how the pathlines are created, GUI command seems the only way to write a pathlines file in Fluent 22.1. And when i read the GUI command of wirte a pathlines file as shown above, the bug would reappears.Â
