Ansys Learning Forum › Forums › Discuss Simulation › Fluids › The flow from the inlet did not pass through the golf ball in the rotating domai › Reply To: The flow from the inlet did not pass through the golf ball in the rotating domai
May 17, 2024 at 2:01 pm
Hi rob, thanks for the reply. I am not sure on the surface setting between the two fluid zone, I designed the domain using boolean subtract on both outer and rotating domain. How do I inspect the fluid zones surface settings?
