Ansys Learning Forum Forums Discuss Simulation Fluids Negative cell volume detected/floating point exception in water entry simulation Reply To: Negative cell volume detected/floating point exception in water entry simulation
Federico
Additionally, negative cell volume error may be due to distance moved per time step may be greater than the edge or cell size in the dynamic region.
You can avoid this problem by giving correct time step size.Â
