Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Possible to Integrate UDF source terms into FLUENT MHD module › Reply To: Possible to Integrate UDF source terms into FLUENT MHD module
May 17, 2024 at 1:17 pm
Electrical conductivity material property isn't available without a model for something that needs it, so that makes sense. Re the other sources etc, check the documentation and tutorials. Can you set any cell zone sources once the MHD module is active? Depending on what you're doing you may want to write the models yourself, and/or explore what Fluent & Maxwell combined can do for you.Â
