Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Bearing graphics in Ansys mechanical › Reply To: Bearing graphics in Ansys mechanical
May 17, 2024 at 12:51 pm
Hello Abhishek, the bearing graphic is only there to show as to which rotation plane the bearing is located.
You can change the size of it according to how much zoomed in you are to the model by simply clicking the Rescale button under the Display Tab of Mechanical.
If you wish you can also stop the bearing from being displayed under the details of the bearing.
