Ansys Learning Forum › Forums › Discuss Simulation › Fluids › ANSYS AQWA : Issue when perform hydrodynamic analysis for irregular waves › Reply To: ANSYS AQWA : Issue when perform hydrodynamic analysis for irregular waves
May 17, 2024 at 12:12 pm
Shuangxing Du
Please check the normal directions of the surfaces in your model. Aqwa requires that the normal directions of the surfaces should point towards the outerside fluid region.
