Ansys Learning Forum Forums Discuss Simulation Photonics cannot convert an FDTD project file (.fsp) into a Lumerical script file (.lsf) Reply To: cannot convert an FDTD project file (.fsp) into a Lumerical script file (.lsf)
Amrita Pati
Hi Minhaz,
The scripts have been updated, however, the scripts are still causing some issues in the newer (2024) releases of Lumerical. If you are using an older (2023) release then it should work. I will report this to the Dev team.
Amrita
