Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Laminar flow and pressure measurements › Reply To: Laminar flow and pressure measurements
May 16, 2024 at 4:11 pm
That's fine. Why would pressure loss increase with a wider duct? Be wary of maximum values without checking where those values are. If you check the area average on the inlet how does it compare across the cases? How do the velocity & pressure contours look?
