Ansys Learning Forum Forums Discuss Simulation General Mechanical Interference-fit-between-two-steel-cylinders Reply To: Interference-fit-between-two-steel-cylinders
Daniel Sami HAMADE
Hello Peter,
Thank you so much for solving my problem! ????
I had entered a wrong value for d0 in my calculations.
Just one last question concerning the values your entered in the online calculator.
If I use d=119.4 mm instead of d=120 mm –> I get a pressure of 82.3 MPa.
I consider that d is the nominal diameter of the interface (after press-fit), based on:
Norton Machine Design Integrated Approach – Norton
Shigleys Mechanical Engineering Eighth Edition Design – Budynas Nisbett
Sami
