Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › changing timoshenko beam theory into euler theory › Reply To: changing timoshenko beam theory into euler theory
erik.kostson
Hi
So beam4 is a 2 node beam element.
In mechanical one then needs a line body ( see here how to define such a line body
https://www.youtube.com/watch?v=5Ef5piegVh4 )
You have a 3D solid body which is meshed with HEX8 or HEX20 3D solid elements so hence the error.
To sum up the geometry created needs to be a line body not a 3D solid like you have, in order to use a beam4 element – look at the video again to see how to define/create a line body.
All the best
Erik
