Ansys Learning Forum Forums Discuss Simulation General Mechanical Cast iron model for Engineered cementitious concrete Reply To: Cast iron model for Engineered cementitious concrete
onur gorur
The elastic modulus for the tension and compression is different as you can see from the experimental data. I tried to correct the code, but the problem still persists. Here is the corrected code. I inserted an additional data point for zero strain and yield stress. However, the second data for tension and compression already has the yield stress values. Therefore, I am a bit confused about what to do. Do you have some other recommendations? I am also including the link to the paper where I got the input parameters for the FEM.
https://www.sciencedirect.com/science/article/pii/S0950061823029884
/prep7
mp,ex,1,20600.0  !Elastic modulus
mp,nuxy, 1,0.15  !Poisson ratio
!Define cast iron model
TB,CAST,1,,,ISOTROPIC
TB,CAST,1,1,4,TENSION
TBPT,,0.0,3.50
TBPT,,0.0002,3.50
TBPT,,0.0007,3.9
TBPT,,0.0127,4.40
TB,CAST,1,1,3,COMPRESSION
TBPT,,0.0,18.50
TBPT,,0.0009,18.5
TBPT,,0.0023,47.3
