Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Condensation and Evaporation coefficient adjustment using Lee model › Reply To: Condensation and Evaporation coefficient adjustment using Lee model
May 15, 2024 at 11:22 pm
Thank you for that. Would you have any idea why i am getting condensation on the cold side of my model? Experimental results find no condensation here, and this makes sense as the air mixture is being heated. The domain is shown below, the vertical stream is the hot moist air and the horizontal stream is the dry cold air. Temperature fields do show that the cold side is indeed heating up. Thank you
