Ansys Learning Forum Forums Discuss Simulation LS Dyna Setting up contacts between an ALE body and a Lagrange body Reply To: Setting up contacts between an ALE body and a Lagrange body
Michael Warfield
Hi Ram,
I've got that connection setup, but I'm getting an error when I try and run "There is not a body defined with reference frame S-ALE domain. Therefore bodies with reference frame S-ALE fille are redundant" I've got one geometry setup as lagrange and the other as S-ALE fill because when I try and select S-ALE domain it's highlighted as yellow and will not let me select. How would I fix this issue?
