Ansys Learning Forum › Forums › Discuss Simulation › Photonics › HPC Licensing Issue › Reply To: HPC Licensing Issue
May 15, 2024 at 7:50 pm
Lito
@schinta3,Â
- Ensure that the cluster nodes are allowed/can access the server on the 2 ports used in the license file in the Ansys LM. Typically, 1055 & 1056
>> Configuring the Ansys license manager for shared access – Ansys Optics - After loading the module for Lumerical, what is the path for fdtd-solutions? Enter the command below in a terminal session.
which fdtd-solutionsÂ
- Have you configured the cluster to checkout the license from your server?Â
- Send the output of the following (from the terminal):
cat ~/.config/Lumerical/License.ini
env | grep ANSYS
- **Do not run from the Lumerical CAD/GUI.
- Please send the submission script you are using to submit/run the simulation.fsp file on your cluster.Â
