Ansys Learning Forum › Forums › Installation and Licensing › Ansys Products › At the result part of total deformation there is not any color change. › Reply To: At the result part of total deformation there is not any color change.
Sampat Kumar
Hello Mert,
Thanks for your patience.
Will you please check the following?
I'm not sure, but you could play the animation and see if the plate material is eroding. This might explain why you're getting large deformation values in the legend but not seeing the contour results on the body itself.
/forum/forums/topic/element-failure-explicit-analysis/
Best Regards,
Sampat
