Ansys Learning Forum Forums Discuss Simulation Fluids Turbine blade setup and solution Reply To: Turbine blade setup and solution
B D
Hi Abod,
Although it will be difficult to comment with available information, here is the reference which will help you with setting up a CHT simulation.
ANSYS Fluent Student: Conjugate Heat Transfer in a Heat Sink - Ansys Knowledge
Additionally, you can perform following steps before starting the simulation:
  1. Perform mesh check and Check case,
  2. Make sure the boundary conditions applied are not conflicting.
