Ansys Learning Forum Forums Discuss Simulation Photonics HPC Licensing Issue Reply To: HPC Licensing Issue
schinta3
The cluster is on the same network as the other local computers. The compute node can succesfully ping the license server. However Lumerical is in an LMOD module, so I cannot access this command. Is there a way to run through an lmod module?
    • /opt/lumerical/v241/licensingclient/linx64/lmutil lmstat -c 1055@licserver01 -a
Best,
Sreyas
