Ansys Learning Forum Forums Discuss Simulation Fluids ansys aqwa error triangulisation Reply To: ansys aqwa error triangulisation
Shuangxing Du
You have duplicated joint (or looped) constraints, which are not allowed in Ansys Aqwa v2024 R1 and earlier versions.
Based on your configuration, it seems that the highlighted structures are rigidly linked.  You could use 4 rigid joints to link these 5 structures.
