Ansys Learning Forum › Forums › Discuss Simulation › Photonics › Solar monitor position not getting updated while using script in model setup › Reply To: Solar monitor position not getting updated while using script in model setup
May 14, 2024 at 3:34 pm
I believe you need script to control the monitor in the analysis group. When you change the z-span of “solar_generation”, does it apply to the monitor location? if not, please try to set the monitor position with a variable related to z-span or a new parameter.
