Ansys Learning Forum Forums Discuss Simulation 3D Design CREATE ENCLOSURE USING SPACECLAIM Reply To: CREATE ENCLOSURE USING SPACECLAIM
castrohenrique0208
Thanks for you answer @Devendra.
I'm working with a composite shell/surface that I need to put into ANSYS ACP and, if I use a solid body, it will be impossible to open ANSYS ACP, because ACP only works with shell elements.
Am I wrong?
Is there any other way to perform the vibration/acoustics of a shell composite?
