Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › changing timoshenko beam theory into euler theory › Reply To: changing timoshenko beam theory into euler theory
May 14, 2024 at 11:29 am
thank you for your response. Sir can you please tell me which real constants I need to insert in commands. After going through several posts, I have found to use the follwing commands:
et, matid, beam4
r,2,.....................
after r,2, I am unable to understand what parameters do i need to enter
beam cross section : 100mm x 100mm x 500mmÂ
