Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Pressure flips direction when I export › Reply To: Pressure flips direction when I export
Rahul
Ensure that you are selecting correct boundary while exporting pressure in Fluent. If you are solving both fluid and solid in Fluent (e.g. CHT analysis), select fluid side boundary to export the pressure on.
Also refer Imported Load (Group) (ansys.com) for more information.
