Ansys Learning Forum › Forums › Discuss Simulation › Platform › Solving Two Way FSI over HPC › Reply To: Solving Two Way FSI over HPC
Rahul
Hello Anas,
Just ensure that you are using correct files on your HPC and check if all the participants files are transferred to HPC.
To run co-simulation at least two coupling participants, one interface, and one data transfer is necessary.
I would recommend you to follow this workshop and refer to user manual to know more about workflow.
Solving Co-Simulations from the Command Line (ansys.com) and Reed Valve FSI Co-Simulation with Partial Setup Export from Workbench (Fluent-Mechanical) (ansys.com)
Using Parallel Processing Capabilities (ansys.com)
Hope this helps!
