Ansys Learning Forum › Forums › Discuss Simulation › Photonics › Inverse Design using EME solver › Reply To: Inverse Design using EME solver
May 13, 2024 at 7:22 pm
Thank you very much for your response.
When I tried to write this command 's=getresult("user s matrix");' in a Python script in Lumerical, I faced the error '"name getresult is not defined." Additionally, I wanted to import my material file in a Python script using 'importmaterialdb("file name.mdf")', but I received the error that it's not a valid command in Python.
Also, I have another question. Should I use an 'if' or a 'for' loop for optimizing my structure using inverse design by the EME module?
I would appreciate if you could help me with these issues.
