Ansys Learning Forum › Forums › Discuss Simulation › Photonics › Changing the monitor position while sweeping › Reply To: Changing the monitor position while sweeping
Guilin Sun
You can use analysis group, and set the monitor and the pillar inside the same analysis group. Please refer to this example: MetamatePLerial parameter extraction - Smith
or use script inside "model" to move the pillar and the monitor at the same time.
If it is for transmission measurement, no need to move the monitor.
