Ansys Learning Forum › Forums › Discuss Simulation › Embedded Software › et_studio_eclipse does not exist in the licensing pool › Reply To: et_studio_eclipse does not exist in the licensing pool
May 13, 2024 at 8:51 am
First of all, you should verify that you have set the environment variable ANSYSLMD_LICENSE_FILE on your machine. This variable should point to the license server in the following way:
Example:
Hope this helps,
Benjamin
