Ansys Learning Forum Forums Discuss Simulation 3D Design Step file not opening in Ansys SpaceClaim Reply To: Step file not opening in Ansys SpaceClaim
Dimitri Goethals
Hi Charudatta,
My apologies for the inconvenience but we had a small break due to a bank holliday.
The step file was created with SolidWorks 2020.
This is the header data of the step file:
ISO-10303-21;
HEADER;
FILE_DESCRIPTION (( 'STEP AP203' ),
    '1' );
FILE_NAME ('YB-016-00182-0E.STEP',
    '2024-04-10T12:36:16',
    'SwSTEP 2.0',
    'SolidWorks 2020',
FILE_SCHEMA (( 'CONFIG_CONTROL_DESIGN' ));
ENDSEC;
There is no other file type available for the customer.
As mentioned if I load in my other available tools and export a parasolid it will load in Spaceclaim as parasolid.
The customer does not have this possibility and only gets the step file form his customer.
Loading the file form a network drive or local drive does not make a difference.
I can reproduce on my system as well. It might be that the file will load if you leave it there for a long time but this is not desirable.
I have uploaded the file in a transfer to Devendra Badgujar because he is handling another issue with corrupt data for me.
So if you need the file, please ask your colleague for it.
Regards
Dimitri
