Ansys Learning Forum Forums Discuss Simulation Fluids Reg: Submission script to submit job on HPC Reply To: Reg: Submission script to submit job on HPC
Swapnil
I tried to simulate the case in HPC cluster but system coupling  log file is written with the following lines while MAPDL log file is blank. Is it because of the unavailability of liscence?
Awaiting connections from coupling participants...
Elapsed time: 5 min. Still awaiting connection from: MAPDL-2. If you feel the participant(s) should already have connected, check participant logs and/or abort the run.
Elapsed time: 10 min. Still awaiting connection from: MAPDL-2. If you feel the participant(s) should already have connected, check participant logs and/or abort the run.
