Ansys Learning Forum Forums Discuss Simulation Fluids How to output the particle information stripped from the edge of the Euler wall Reply To: How to output the particle information stripped from the edge of the Euler wall
gwqsz
Thank you very much for your reply. In fact, I have tried this method before, but I found that after removing the duplicate particle ID in the resulting file, the number of particles is not consistent with the number of s stripped from the Euler wall film, and there is always a part of particle id not in the resulting file. I can confirm that this omission is not caused by manipulation of the resulting file.
