Ansys Learning Forum › Forums › Discuss Simulation › Photonics › HPC Licensing Issue › Reply To: HPC Licensing Issue
May 11, 2024 at 1:38 am
Is the cluster on the same network as the laptop/desktop and the license server?
Ensure that the compute nodes can access/connect to the license server on ports used in the license file on the server (default: 1055 & 1056). Â
Are you able to check the license manager status on the server from the compute nodes?Â
>>> How to check license status and availability (from the client machine running Lumerical)Â
Does it show the LM up and running and the available licenses for checkout?Â
