Ansys Learning Forum Forums Discuss Simulation Photonics HPC Licensing Issue Reply To: HPC Licensing Issue
schinta3
>Rocky Linux release 8.8 (Green Obsidian)
>Lumerical 2024 R1.3
Right now, we can open and run Lumerical on other laptops/desktops that can access our existing server on the same network. Essentially the above error is thrown when I try to run the fdtd-engine from command line, while this SLURM script with those commands send the job to a compute node, despite having the correct ANSYSLMD environmental variable.
