Ansys Learning Forum Forums Discuss Simulation Fluids How to output the particle information stripped from the edge of the Euler wall Reply To: How to output the particle information stripped from the edge of the Euler wall
OK, Set the interior (fluid facet zone) instead. The resulting file is all of the DPM interactions with the surface so you'll need to do some data management to find the first time a particle ID is used.
