Ansys Learning Forum Forums Discuss Simulation Fluids Connection Stiffness Ansys AQWA Reply To: Connection Stiffness Ansys AQWA
S.S.S.ShankaVasuki
No, the damping has a significant effect on the Heave RAO. Also the stiffness of the joints have been taken from the reference paper so I guess it should be correct as they have used the same values in aqwa have got good match with experimental data. I am not able to figure out what exactly I am missing. Would it help if I share my workbench file?
