Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Connection Stiffness Ansys AQWA › Reply To: Connection Stiffness Ansys AQWA
S.S.S.ShankaVasuki
Thank you for your response. You mean 0.71975 rad/sec right? I did try with the input parameters as you mentioned, but I still get the same results. But I do somehow feel that the damping of certain bodies is leading to increase/decrease in the response. I am actually not sure on how to fix this issue. Would it be alright if I share my workbench file here?
Also, regarding your other questions:
  1. The water depth is set as 58.5m as per the reference paper.
  2. All the structures are in a hydrodynamic interaction group as shown in the figure below.
Please let me know on how to fix this issue. thank you for your help!
