Ansys Learning Forum › Forums › Discuss Simulation › Fluids › How to output the particle information stripped from the edge of the Euler wall › Reply To: How to output the particle information stripped from the edge of the Euler wall
May 10, 2024 at 9:29 am
Check the DPM Summary options and set the film wall surface. You'll need to check if the file contains the creation (flow) time or flight time.Â
