Ansys Learning Forum Forums Discuss Simulation Fluids Dissolving a salt crystal Reply To: Dissolving a salt crystal
Yes.  However, unless you are going to code up moving mesh on the walls to mimic the mass loss you may not see what you want. Starting point for the above might be surface reactions or Eulerian Wall Film. Note, neither approach is simple and may require User Defined Functions to be written.
