Ansys Learning Forum Forums Discuss Simulation Electronics Use of symmetry boundaries for symmetric power dividers/combiners Reply To: Use of symmetry boundaries for symmetric power dividers/combiners
Faezeh Tork Ladani
Hi Roger,
The best option is not using the symmetry when the multiplier does not apply to all the ports. If you use it, then interpreting the S parameters is not straightforward. If you have access to customer portal, file a support case so you can discuss this further with one of our engineers.
