Ansys Learning Forum Forums Discuss Simulation Photonics HPC Licensing Issue Reply To: HPC Licensing Issue
Lito
  • Which Linux distro and version are you running on the cluster?
  • Which version of Lumerical are you using?
  • To clarify, you can open and run the Lumerical CAD on the same node/host (login.rockfish.jhu.edu) -- where you are having issues running the simulation.fsp file from?
  • Or you are opening the Lumerical CAD via VNC on a different node/host on the cluster not on the node (login.rockfish.jhu.edu)?
