Ansys Learning Forum Forums Discuss Simulation Fluids Heat exchanger Reply To: Heat exchanger
You can't. Heat will pass from the fluid to the solid based on the temperature and flow conditions. You could use Expressions/UDFs to monitor the outlet temperature to adjust the inlet until you get to the desired value.
