Ansys Learning Forum › Forums › Discuss Simulation › Fluids › In Fluent, the continuity residual not converging › Reply To: In Fluent, the continuity residual not converging
Hello Rob!
Does contours meaning the plane or streamline? Sorry I am not very sure what is contours.
The flow is all good.But I am researching the DPM result.
When I run different iterations,the DPM track of escaped parcels is totally different.
Like 100 track escaped in 400 iters and 300 track escaped in 450 iters.
I have ask the DPM problems in the other post,and I got an answer siad my simulation had not converged.
So I run 1000up iters to assure my DPM result.And its continuty always so high,so I am not sure is it normal or not.
And my proffesor also confused why my continuty is so high.
Thank you Rob!
