Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › how do i stop surface penetration? › Reply To: how do i stop surface penetration?
peteroznewman
Under the Connections folder insert a Contact Tool then right click and select Generate Initial Contact Status.  Look at the Status for the contact. If it says Near Open, that is good. If it says Far Open, that is the reason the contact is not working.  To make it show Near Open, edit the contact and on the line that says Pinball Radius, enter a value larger than the distance between the surfaces.  Now regenerate the initial contact status and check that is shows Near Open.
I can't see the top of the block in the display, only the side of the block which is part of the contact.  Is the top also selected?  It would be better if the top was the only face on the block to be in the contact definition, along with the underside of the long thin beam.
