Ansys Learning Forum Forums Discuss Simulation 3D Design Service pack 3 does not work Reply To: Service pack 3 does not work
Roberto Granito
Hello Charudatta
I would also like to point out another error, after updating the patch it is no longer possible to open scdoc files with a double click, even by setting the application as default.
I have to solve this problem by changing the registry file, this happens often, this problem must be solved for the next versions, the user must not perform these operations often.
Regards
