Ansys Learning Forum Forums Discuss Simulation Photonics Lumerical version change results in output discrepancy Reply To: Lumerical version change results in output discrepancy
Guilin Sun
Since the forum can only show limited information, it is hard for us to diagnoze the cause.
You mentioned "Could this issue be related to changes in the initial E field during the sweep or other modifications in hidden parameters between the versions?" may I know what does "the initial E field" mean here? did you chage the source amplitude? or any other change to the simulation files? the phase change is a 2pi jump, or slight change in magnitude? please elaborate more on this. Thank you!
