Ansys Learning Forum › Forums › Discuss Simulation › 3D Design › discovery intake sim › Reply To: discovery intake sim
nicolino.ruotolo
Dear Devendra,
thank you...it worked properly by slightly reducing the fidelity.
Then, I moved to the whole project. Despite the fact each of the components had been succesfully (the last one that converged is the one you helped me with in this thread) on it own, when it comes to the whole structure and despite the fact the geometry check is ok, I get the following feedback (to get it done it takes some 15 minutes):
I should realize it is in the interface between each of the parts of this structure. But it is an hard work when you have no feedback during the geometry check. Any suggestion from your side to expedite check of which part could affect the result? I already tried to lower just a bit the fidelity but the outcome is the same. One more: in yellow (!) Surface bodies will be excluded form the simulation (1 body). Have you any idea why this surface (which coincides with outlet) is excluded?
 Thank you
Nico
