Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Heat transfer between material solar panel › Reply To: Heat transfer between material solar panel
May 8, 2024 at 2:36 pm
If you've got temperature dependent density where does the extra volume go? Ie if material expands when it gets warm and the volume is fixed convergence may suffer.
Talk to your teacher, and in Fluent right-click on the options in the tree & look for "modified settings". What have they set that you haven't?
